web launcher without network and page hosted on device
Hello, I am testing your OS to use it without a network, so I would like to use a hosted page on my device, is it possible?
And if it were possible:
In which folder should I save the files of my website?
And what would be the correct way to write the address of my default website?
Congratulations on your product.
You would put all the files in the /sdcard directory, which is "External Storage" in Android.
To load in a webview, you would use the context.getExternalFilesDir() method in java. Your app would also need read_external_storage permission.
The URL will be of the form file:///(path_returned_by_method)/filename
Thanks for your reply.
Excuse my ignorance but I don't know where or how to use "context.getExternalFilesDir() method in java", could you give me some more indication?
Grateful
That is a command in the java file management API. You would need to write a custom app (java) to get this. You can then use that URL to load your pages within a Webview View in your custom app.
