problem with javascript
in OS features
Hello, I have installed my app to use it in kiosk mode. The app has been created from an html5 website that works with jquery and jgallery.
In EMTERIA the js files are not working, any idea why and how I could fix it?
I have tested the app on a mobile and it works fine.
Thanks
likely the webview you are using in your app does not have javascript enabled.
@storm, please try opening the emteria website in your kiosk browser. If it works, JS is enabled.
