Rock Pi 4 does not start after a shutdown
I am running into a weird problem. I have installed the OS 3 times already and each time after the initial powerup the board simply will not start.
When connected to power the green turns green, but the blue one does not flash and there is no output on HDMI
Is there a hardware button to powerup?
I tried both shutting down from the OS and simply removing power. Each time the same result, after reconecting the power the boar wont power up.
Thank you for your help!
Here are some things you can try:
If you have tried all of the above and you are still having trouble, you may need to contact the Rock Pi support team for assistance.
Here are some additional tips for troubleshooting your Rock Pi 4:
If you are still having trouble, you can try searching for help on the Rock Pi forums or on the Rock Pi subreddit.
I hope this helps!
Thank you so much for all your advices!
In the end i was able to pinpoint the problem to the sdcard.
It was probably a cheap one and it got fried probably from the heat
Glad it worked![:) :)](https://forum.emteria.com/resources/emoji/smile.png)
