MMOEXP-Master the Scholar General Build in Elden Ring
In Elden Ring, build variety is one of the defining strengths that keeps players experimenting hundreds of hours into their journey. Among the many hybrid archetypes that have emerged, the Scholar General build stands out as a flexible, intelligent warrior who blends magic, battlefield control, and melee efficiency into a single cohesive playstyle. This guide breaks down how to create and optimize a Scholar General build, including stat distribution, gear choices, combat strategy, Elden Ring Runes and scaling potential for both PvE and PvP.
The core idea behind the Scholar General is simple: you are not just a spellcaster or a melee fighter, but a tactician who controls engagements. You dictate pace, spacing, and damage types while adapting to different enemies. This makes the build especially powerful in late-game content and New Game Plus cycles, where versatility often outweighs specialization.
Starting with attributes, Intelligence is your primary stat. This fuels your sorcery damage and unlocks access to high-tier spells. Aim to push Intelligence to at least 60 in the late game, with room to go higher depending on your level cap. Mind is equally important, as it determines your FP pool. A Scholar General relies on consistent spell usage, so maintaining a healthy FP reserve is critical. Around 25 to 35 Mind is a strong baseline.
Vigor should not be neglected. While you are not a pure tank, survivability is essential, especially when facing aggressive bosses or engaging in PvP. Target at least 40 Vigor for endgame viability. Endurance can be kept moderate, enough to support medium armor and a weapon without fat-rolling. Strength and Dexterity should be leveled only to meet weapon requirements unless you are leaning into a hybrid scaling weapon.
Weapon choice is where the Scholar General begins to shine. Intelligence-scaling weapons are the natural fit. Options like magic-infused straight swords, greatswords, or thrusting weapons allow you to weave melee attacks between spells. A weapon with good scaling in Intelligence ensures that your investment in sorcery also boosts your physical damage output.
Staff selection is equally important. Early on, prioritize staves with solid scaling, but as you progress, transition into high-tier staves that maximize your spell damage. Upgrading your staff should be a top priority, as it directly impacts your overall damage more than most other gear pieces.
Spell selection defines your battlefield role. A well-rounded Scholar General carries a mix of offensive, defensive, and utility sorceries. Fast-casting projectiles allow you to pressure enemies at range, while heavier spells provide burst damage during openings. Area-of-effect spells are excellent for crowd control, particularly in dungeons or large encounters.
Defensive spells and buffs should not be overlooked. Magic shields, damage negation spells, or utility effects can significantly enhance your survivability and adaptability. The goal is to always have an answer to the situation in front of you, whether that means zoning enemies, bursting them down, or repositioning safely.
Armor selection follows a balanced approach. You want enough protection to survive hits, but not at the cost of mobility. Medium armor sets are ideal, allowing you to maintain a medium roll while still benefiting from respectable defenses. Poise can be valuable if you intend to trade hits in melee, but it is not mandatory.
Talismans play a critical role in optimizing the build. Focus on items that boost sorcery damage, reduce FP consumption, or enhance overall survivability. Combining offensive and defensive talismans ensures that you remain effective in prolonged fights without becoming too fragile.
In combat, the Scholar General excels at controlling spacing. Open engagements with ranged sorceries to soften enemies and force movement. As opponents close the distance, transition into melee attacks to conserve FP and maintain pressure. This constant switching between magic and melee keeps enemies off balance and allows you to adapt to different attack patterns.
Against bosses, patience is key. Use your ranged options to learn attack patterns and create safe windows for damage. Once you understand the rhythm of the fight, integrate heavier spells or melee combos during openings. The versatility of the build allows you to adjust your approach depending on the boss, making it highly effective across the game's diverse encounters.
In PvP, the Scholar General becomes a mind game. Opponents must respect both your spellcasting and your melee capabilities, which creates opportunities to bait reactions. Mix fast spells with delayed casts to disrupt timing, and use melee attacks to punish aggressive players. Positioning and unpredictability are your greatest strengths.
Scaling into the late game, the Scholar General remains highly viable. As your Intelligence increases and your gear improves, both your spell and weapon damage scale effectively. This dual scaling ensures that you never feel underpowered, even in high-level content.
One of the biggest advantages of this build is its adaptability. Unlike pure builds that may struggle against certain enemy types, the Scholar General can adjust damage types and strategies on the fly. This makes it an excellent choice for players who enjoy experimenting and refining their approach.
In conclusion, the Scholar General build in Elden Ring offers a dynamic and rewarding playstyle that combines the best aspects of sorcery and melee combat. By focusing on Intelligence, maintaining balanced defenses, cheap Elden Ring Runes and mastering the flow between ranged and close-quarters combat, you can create a character capable of handling any challenge the Lands Between throws at you. Whether you are exploring, fighting bosses, or engaging in PvP, the Scholar General stands as one of the most versatile and powerful archetypes available.
