Sushell does not work on Android 16
I need to use sushell for my project, and i noticed that it does not work on any of Android 16 build (tested on Raspberry Pi CM4 with: 16.1.0, 16.2.0 and 16.2.17). On adb shell it returns 255 and with help from chatgpt I managed to investigate that sushell daemon simply does not start on boot. I quickly checked Android 14 version and there it works. Could you fix that and upload some nightly build with that fix? I will be gratefull.
Hi @Nexwell. Thanks for reporting it. We have found the problem. I am sure it will be fixed in the next days. I'll let you know when a new release is available.
