Problems with Emteria.OS_Installer-x86_64
Hello, when I try to download the latest version 5.8 (the automatic update from Rasp did not work) the installer Emteria.OS_Installer-x86_64 stops in step 3 and does not progress, although it does recognize the memory. Could you tell me if it is a fault of the installer? or in what format should I format the memory before inserting it? or if something else happens to them? I'm doing it in FAT32, greetings and thanks
Can you provide the installation log?
Hi, of course! I remind you that the installation is stopped in step 3 (Drive) after recognizing the memory:
fernando@fernando-MS-7996:~/Descargas$ sudo ./Emteria.OS_Installer-x86_64.AppImage
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
file:///tmp/.mount_EmteridnEFdc/usr/qml/QtQuick/Dialogs/DefaultFileDialog.qml:210:25: QML ListView: Binding loop detected for property "model"
qrc:/main.qml:221:17: QML Rectangle: Binding loop detected for property "height"
Refreshing drives
Found 1 drives
Thanks, but this log doesn't show any errors related to to flashing.
being thus I will then try to buy a new micro SD to USB adapter, I close the related dialogs and I appreciate the help!
