Not able to flash to SD card
Running windows 10 64- bit
getting error failed writing partition image, failed writing from image boot.zip
here is the error log
+00:00 (, 0) Starting emteria installer v0.5-2-g55cc940
+00:01 (qrc:/main.qml, 221) qrc:/main.qml:221:17: QML Rectangle: Binding loop detected for property "height"
+00:11 (, 0) Refreshing drives
+00:14 (, 0) Found 1 drives
+00:18 (, 0) Downloading "package.json"
+00:18 (, 0) Using path "C:/Users/ssingler/AppData/Local/Emteria/Installer/rpi3-v0.5.11/package.json"
+00:19 (, 0) Finished download of "package.json"
+00:19 (, 0) Checking for OEM config...
+00:19 (, 0) Retrieved OEM config len = 0
+00:19 (, 0) Downloading "boot.zip"
+00:19 (, 0) Using path "C:/Users/ssingler/AppData/Local/Emteria/Installer/rpi3-v0.5.11/boot.zip"
+07:27 (, 0) Finished download of "boot.zip"
+07:27 (, 0) Downloading "oem.zip"
+07:27 (, 0) Using path "C:/Users/ssingler/AppData/Local/Emteria/Installer/rpi3-v0.5.11/oem.zip"
+07:32 (, 0) Finished download of "oem.zip"
+07:32 (, 0) Downloading "system.zip"
+07:32 (, 0) Using path "C:/Users/ssingler/AppData/Local/Emteria/Installer/rpi3-v0.5.11/system.zip"
+64:26 (, 0) Finished download of "system.zip"
+64:26 (, 0) Finished DownloadWorker
+64:26 (, 0) Flashing on raw "\\\\.\\PHYSICALDRIVE1"
+64:26 (, 0) Initializing PackageWriter
+64:26 (, 0) Package base path: "C:/Users/ssingler/AppData/Local/Emteria/Installer/rpi3-v0.5.11"
+64:26 (, 0) Drive: "Mass Storage Device USB Device" with 15523119104 bytes
+64:26 (, 0) Raw at "\\\\.\\PHYSICALDRIVE1"
+64:26 (, 0) Mounted at "D:"
+64:26 (, 0) PackageWriter initialized successfully
+64:26 (, 0) Starting step 0 Reading package
+64:26 (, 0) Finished step 0 Reading package
+64:26 (, 0) Starting step 1 Verifying files
+64:27 (, 0) Finished step 1 Verifying files
+64:27 (, 0) Starting step 2 Preparing
+64:28 (, 0) Diskpart output: "\r\nMicrosoft DiskPart version 10.0.10586\r\n\r\nCopyright (C) 1999-2013 Microsoft Corporation.\r\nOn computer: MIS9000\r\n\r\nDisk 1 is now the selected disk.\r\n\r\nVolume 3 is the selected volume.\r\n\r\nDiskPart successfully removed the drive letter or mount point.\r\n\r\nPlease wait while DiskPart scans your configuration...\r\n\r\nDiskPart has finished scanning your configuration.\r\n"
+64:28 (, 0) Diskpart error: ""
+64:31 (, 0) Diskpart output: "\r\nMicrosoft DiskPart version 10.0.10586\r\n\r\nCopyright (C) 1999-2013 Microsoft Corporation.\r\nOn computer: MIS9000\r\n\r\nDisk 1 is now the selected disk.\r\n\r\nDiskPart has encountered an error: Access is denied.\r\nSee the System Event Log for more information.\r\n"
+64:31 (, 0) Diskpart error: ""
+64:37 (, 0) Diskpart output: "\r\nMicrosoft DiskPart version 10.0.10586\r\n\r\nCopyright (C) 1999-2013 Microsoft Corporation.\r\nOn computer: MIS9000\r\n\r\nDisk 1 is now the selected disk.\r\n\r\nDiskPart succeeded in cleaning the disk.\r\n\r\nPlease wait while DiskPart scans your configuration...\r\n\r\nDiskPart has finished scanning your configuration.\r\n"
+64:37 (, 0) Diskpart error: ""
+64:39 (, 0) Finished step 2 Preparing
+64:39 (, 0) Starting step 3 Opening to write
+64:39 (, 0) Finished step 3 Opening to write
+64:39 (, 0) Assuming drive has 30318592 sectors
+64:39 (, 0) Processing 4 partitions
+64:39 (, 0) Processing partition "boot"
+64:39 (, 0) Using LBA of 2048
+64:39 (, 0) Size determined from zip source: 65011712
+64:39 (, 0) Partition will occupy 126976 sectors
+64:39 (, 0) Processing partition "system"
+64:39 (, 0) Using LBA of 129024
+64:39 (, 0) Size determined from zip source: 2147483648
+64:39 (, 0) Partition will occupy 4194304 sectors
+64:39 (, 0) Processing partition "oem"
+64:39 (, 0) Using LBA of 4323328
+64:39 (, 0) Size determined from zip source: 536870912
+64:39 (, 0) Partition will occupy 1048576 sectors
+64:39 (, 0) Processing partition "userdata"
+64:39 (, 0) Using LBA of 5371904
+64:39 (, 0) Processing dynamically sized partition "userdata"
+64:39 (, 0) Partition will start at LBA 5371904
+64:39 (, 0) Remaining sectors on drive: 24946688
+64:39 (, 0) Starting step 4 Writing MBR
+64:39 (, 0) Partitions in MBR:
+64:39 (, 0) Partition 0 bootable true LBA 2048 size 126976
+64:39 (, 0) Partition 1 bootable false LBA 129024 size 4194304
+64:39 (, 0) Partition 2 bootable false LBA 4323328 size 1048576
+64:39 (, 0) Partition 3 bootable false LBA 5371904 size 24946688
+64:39 (, 0) Finished step 4 Writing MBR
+64:39 (, 0) Starting step 5 Writing file
+64:39 (, 0) Using zip file at "C:/Users/ssingler/AppData/Local/Emteria/Installer/rpi3-v0.5.11/boot.zip"
+64:40 (, 0) Failed writeRaw: 0
+64:40 (, 0) Tried to write 8388608 bytes
+64:40 (, 0) error in mz_zip_reader_extract_to_callback
+64:40 (, 0) Failed extracting zip file: write calledback failed
+64:40 (, 0) Failed unzipping file
+64:40 (, 0) Failed writing partition content for "boot"
  • anybody have any thoughts on this?
  • Found the problem. I had the same issue untill I uninstalled and reinstalled the launcher.
  • Still getting the same error after reinstall.
  • Do you have a possibility to test it with another PC or another sdcard adapter? We don't have a list of officially supported ones yet.
  • I'm having the same problem
  • I'm having the same problem Not able to flash to SD card
