Anyone get a decent TTS engine working?
The Pico TTS that comes with Emteria is awful. Has anyone gotten the google one working? I installed the APK via adb for it, but it doesn't seem to work when I hit the test button.
I've also installed the old APK for IVONA voice, but it doesn't work either. It looks like the files for the IVONA Amy voice are in /sdcard/Android/obb as well.
Hah, got it. I installed the main IVONA package first. Then I downloaded the IVONA Amy xapk file. Renamed it to a .zip file and extracted it. I then copied the contents of it to the com.ivona.amy.xxx directory in Android/obb. Then I installed the .apk that was extracted from the xapk. Works!
Awesome work! Thanks for sharing.
