Crispy Sound on Ugreen USB Audio
Hi,
i have massive Audio bugs when using Ugreen USB Audio.
no matter if i use Youtube, soundcloud or other , as far as i can see if Device has SDcard R/W operations
Sound get´s messed up. If its some sort of cached, the Audio sounds clear
Using Raspberry 3 B+
rgds,
brian
  • Are you feeding the speaker with USB power from the raspberry pi? This can cause the ground from the USB to mix with the ground of the audio and give you lots and lots of snow buzz or whatever it's called in English.
  • Hi Nabula,
    No, just using regular headphones.
    I might try different headphones or Speakers.
    Will Keep you informier.
    Rgds,
    Brian
