simply mount sd card
Hi there.
I would like to edit my /boot/config.txt file. I normally use the nano command, but this doesn't work since the file system is only read able. On Emterias web page, they write; "Simply mount sd card, and edit config.txt file."
But how do i do that? I tried going into settings, storage - but without succes.
Please help ![]()
Best Regards
Either via ADB or put the sdcard into a Linux PC.
Currently, I don't have a Linux PC. I have installed the Android Studio, but i can't figure out, how to esthablish the ADB coonnection. All the "how to setup" is based on an USB connection, and the how to make ethernet connection is pure raspberry pi(no android).
I'm stuck. Where can i find a "how to setup ADB connection over ethernet for an android based raspberry" ?
I managed to set up the ADB connection via ADB. But still - all the files are read only. How do i change that?
I would advise to set up an Ubuntu VM and mount the SD-card in there to modify the files. If you use ADB you can mount volumes as read only or read/write. Use:
adb shell "mount -o ro,remount /volume_name"
and
adb shell "mount -o rw,remount /volume_name"
Agreed, easiest way is to put it in a Windows PC if that is what you have. I tried ADB, etc, all this CLI stuff does my head in to be honest.
