Android will not load on my RPi3B v1.2 if I have the sense hat installed (Works with Raspbian)
Android will not load if I have the sense hat installed It gets as far as loading kernel then hangs
(Works fine without the sense hat) (Works fine with the sense hat and Raspbian)
Also I have a 5 inch HDMI LCD (B) waveshare touch screen attached and the touch screen function is not working but the display is fine.
Any suggestions?
Steve
Como has podido instalar en la misma MicroSD raspbian y emteria?? Me interesa. Gracias.
I changed the Micro sd from the Android one to the Linux one to check the hardware itself was not faulty. When I did this the Sense hat worked fine. Changing the micro sd back to android and made the android hang if the sense hat was still installed.
I'm not quite sure what exactly that hat does to the pins. Can you post a link to the product description?
