Force Sound through HIFI Sound card
Hello
I am havin problems in trying to force sound through a hifi sound card.
I have this card https://amazon.com/Inno-Maker-Raspberry-PCM5122-Audio-Expansion/dp/B07D13QWV9
that i purchased to improve on the rather poor quality sound coming from my pi's 3.5mm jack
On the Raspbian OS, you include this line on the /boot/config.txt
dtoverlay=allo-boss-dac-pcm512x-audio
Then comment out this line
dteoverlay=lirc-rpi
And the sound i get from the hifi card is awesome when using RasbianOS
Now,i cant edit /boot/config.txt on the MicroSD with Emteria! (using 6.0) Meaning, i cant use that card
Reason?
When i slide in my MicroSD (through its reader) into my laptop's MicroSD slot,laptop cant see the card! (Using on different laptops ,one with Fedora 27 and the other,Windows 10)
I also cant edit it directly while the card is on the pi and i have booted the SBC through this card
Please Help!!!!
This sounds like your PC isn't mounting the card properly. Why? I don't know - I can edit the config file on all of my cards in both Windows 10 and Ubuntu 16.04.
