Revert to older versions
how i can go back to stable version 0.7.1?
  • You have to re-install from scratch. What problems do you have?
  • problem is solved. the resolution in system of 1.0 was to high for 7 " touchscreen.
    i pluged a monitor with hdmi and changed the resolution. now everything is fine.
    thanks
    marcello
