Setting Default Sound Device
I have added a USB sound card to my rpi Emteria system. It works fine, but it is now the default sound device for everything in Emteria.
How can I set the default sound device Emteria uses to something else ? Or even switch sound devices on the fly?
  • Commandline? Unsure what Linux command would do that?
  • Yup from the command line would be fine so the equivalent of something like:
    pacmd "set-default-sink "
    Which is (I think) how you change this in ALSA in a desktop distro, but Android has a much lighter userspace ALSA.
  • For some context, I can play out of a USB sound card with aplay easily enough, for the application I have in mind. But as soon as I plug in the USB sound card it becomes the default sound device, how can I make the built-in Rpi audio out jack the default again?
  • edited February 2020
    How can I access the Command line locally?
  • Enable the local terminal in the developer settings or connect with ADB and type "adb shell".
    Thanks, I got the terminal working, just had some difficulty finding the setting.
    However the pacmd command does not seem to be recognized by the terminal.
    I have tried every audio interface I can think of and nothing...
    What interface does emteria use?
  • sudo infront of the command?
  • sudo is not recognized either, I believe "su" is used instead.
    Even with that, all I get is: " sh: pacmd: not found"
  • UPDATE:
    I now realize that Emteria uses TinyALSA for audio control.
    "tinymix" is the installed audio mixer/config tool
    After some editing of the audio_policy_configuration.xml file,
    I was able to restructure the default audio input and output.
  • Would an audio hat be an option?
