Problems with iiyama 19" ProLite T1931SR
Hi,
I've just bought a Iiyama 19" touchscreen on which I would like to run and Android app using EmteriaOS on a Raspberry Pi 3+.
However, no matter what I do, I can't make it work. The screen won't display any picture and all I see when I start the Raspberry is a rainbow screen and then nothing. When I connect it to 7" Raspberry Touch screen with pins it works very well but this doesn't. It goes without saying that the touch doesn't work either.
I've tried it with the same Raspberry but with other OS and it works - so I guess there is some way to make this work but I can't figure out how.
Have anyone else tried this? Do any of you guys have a thought on what it could be? Any suggestions?
Thankful for all the help I can get. :)
Best regards,
Kristian
Best regards,
Kristian
I assume you need no additional configuration to use it with other OSes? Do you know what resolution it supports?
