RPi 4 (emteria.OS v11.2.0) - USB-RS232 driver problem
in OS features
We test sending USB-RS232 commands using Aten UC 232A. And we came across a problem where RPi4 does not register Aten USB-RS232 as ttyUSB0, but as xhci_hcd. On RPi3 (emteriaOS 1.3.0) everything works properly, Aten registers as ttyUSB0 (pl2303) and commands can be sent to it.
We want to ask why the RPi4 USB-RS232 converter registers badly and not like ttyUSB0?
Regards,
F. Slezák
Hi,
I would like to remind my question about RS232 on rpi4.
Hey @kiwi,
sorry for the late reply.
A lot of things changed from RPi3 to RPi4 eg. USB drivers. xhci_hcd is the USB3 driver.
RPi4 has 2xUSB 3 and 2xUSB 2 ports have you tried a different port?
Another option to try would be adding
dtoverlay=dwc2,dr_mode=hostto your config.txt to change the USB driver.Another question from my side would be why are you using a USB to RS232 converter isn't the built-in UART on PIN14&15 sufficient for your use case?
Regards,
Jan
Hi,
thanks for the reply, the ports we tried and the behavior is the same.
Where exactly should config.txt be located? In the /boot folder?
Regards,
Filip
Hi,
so i found it in the /boot folder, but it's set up correctly. Can you think of another solution?
@kiwi
The
dtoverlay=dwc2,dr_mode=hostyou have in the config.txt is only applied when running on a compute module (cm4). If you are running a normal RPi4 you need to put it under the [all] guard.Meaning: try to copy line 3 to somewhere after line 6.
@kiwi
Have you been able to solve this in any way? We have the exact same problem with our serial device which gets registered as xhci_hcd, and no ttyUSB* device is added when plugging in the device. I have tried all of the USB ports, getting the same result.
We have tried to move the
dtoverlay=dwc2,dr_mode=hostline to be included under the [all] line as @smieschek suggested.Everything is working perfect when running a RBPi3 running emteria.OS v7.3.0 but not with our RBPi4 running emteria.OS v11.3.0.
Does anyone have an update on this?
@linusekstrom Another customer had a similar issue and we were able to fix it. Can you try nightly v11.6.10 for RPi4 and see if your device gets listed?
