Orientation 90 and 270 the same
When I set screen orientation to 90 degrees and then to 270 degrees it is the same and when I put on orientation lock it defualts to90 degrees anyway. I need 270 degrees because of the location of the power port on my Raspberry Pi.
Hi @peterjbdk thanks for reporting. I think we have already fixed this issue. Can you try again with a current nightly version? If it works it will be part of the next release.
