Yahboom RGB cooling hat with adjustable fan and OLED display
edited January 2022 in Supported peripherals
I am trying to install the above and I have tried both the C_Code and Python_Code zip files off their website and neither work for me on Emteria. Both hang up on installation. Can anyone who has installed one of these help? It would be really nice to have some cooling. Temp is running above 65 DegC. The download file name is temp_control.zip
  • Hi @NZGTT ,
    The manufacturer seems to only provide installation scripts for Linux. You can ask if there is an android solution present. Otherwise, you will have to at least cross compile the c_code and adjust the paths in the install script. Alternatively, you can write you own app as they provide the I2C communication protocol.
    Good luck!
