Wifi problem
I installed the os via the installer and been having problem with wifi
whenever i connected the device to wifi, it would work for about 10 - 20 seconds and then it would say "Wifi connected, no internet"
thank you in advance.
I also get this "Wifi connected, no internet", but wifi is work!
Check your system time (may be a SSL issue).
I have the same problem. System time and time zone is set correctly
This is the case with me, but not all internet connections. At Youtub I encountered this bug in some radio programs. It can only be turned back when I restart the system.
We have fixed the reconnect problem in the latest release. Please switch to 0.5.0.
