Bluetooth problems on Rock PI 4 SE
Is there any chance the Bluetooth might work better in future updates for the Rock PI?
In the newer version the connection sometimes disables on its own and the clicking the enable button simply does not work.
This seems to happen less often in the initial 11.1.0 version from our experience.
Hi @gabrielsolomon![:) :)](https://forum.emteria.com/resources/emoji/smile.png)
In principle there is the chance that Bluetooth might work better in future updates.
It's a known issue that re-enabling Bluetooth does not work on the RockPi: https://emteria.com/kb/known-issues-rock-pi-4b
There is an open issue for that in their github: https://github.com/radxa/manifests/issues/12
Maybe you can push it
Is Bluetooth crucial for your use-case? If that's the case, we should have a call to discuss all options.
