Enable Raspberry Pi 4B SPI GPIO Interface
Hello All,
it is easy to enable the SPI interface in Emteria OS 7.6 on Rasp 3 B+. Just add "dtparam=spi=on" in config.txt.
I try the same approach in Emteria OS 13.3 on Rasp 4. It does not work.
Does anybody known, if SPI is supported on Rasp 4 ? If yes, how to Enable it ?
Thanks a lot in advance !
Hi @jshen
In theory it should work the same under Android 13. How are you testing/using the SPI?
Only think that comes to my mind is that maybe some kernel modules you require are not included anymore. You can see our kernel config here: https://github.com/emteria/kernel_brcm_rpi/blob/v5.15.94/arch/arm64/configs/bcm2711_aosp13_defconfig
The CONFIG_SPI_SPIDEV module needs to be loaded manually now and the CONFIG_MMC_SPI is not included. Do you require any of these?
Hi @smieschek ,
I am having a similar issue, using SC16IS752, specifically https://www.waveshare.com/2-ch-rs232-hat.htm.
I added "dtoverlay=sc16is752-spi1" to /boot/config.txt but it does not work.
Hardware works fine on raspberry pi 4b with Raspberry Pi OS and Ubuntu.
Hi @bolekro
Which RPi Model and what emteria.OS version?
The overlay should be present in principle. You could check dmsg if it's loaded.
You should also rather use config-overrides.txt
https://www.waveshare.com/wiki/2-CH_RS232_HAT also mentions a int_pin. Did you look into that?
Thanks for prompt reply.
OS version 13.4.0.
int_pin is optional, only required if not using default, which I am (using the same config on Ubuntu on PI).
I migrated to config-overrides.txt to prevent loss on update.
What should I look for in dmesg? I tried 'dmesg | grep sc16" but nothing is found.
Yes, that's what I would have grepped as well. When you are booting Ubuntu on Pi does it appear in dmesg?
