Emteria Android for Raspberry PI small summary
I'm searching for the possibility of starting APK on RPI 3B+ or RPI CM4 and tried Emteria.
It works somehow but:
- For RPI 3B+ available only Android 7 version. it is very outdated for me
- 11.11.0 not working on CM4 and hangs on the logo
- 11.8.0 works on CM4 but there are no Android settings at all (only Emteria settings), no file browser, even f-droid not working and firmware works with lags
Is anybody get it working?
Thanks
Hi @testbomber
We are about to release Android 13 for the CM4. You could give the nightly a shot.
Thank you very much for your reply. Please find my clarifications below
Oh, thanks for nightly hint I will try
Automatic nightly build 13.0.1 build, timestamp 1690984911. Reboot, Reboot and one more time reboot after kernel loading
@smieschek Any suggestion?
@testbomber not really, I have almost the same setup, except the 4GB RAM version of the CM4, but 2 GB should be enough. If I understood correctly, you don't even get to the bootanimation?
Do you have a UART Bridge to get some logs? You might try a different SD card, but that's a wild guess.
Do you have any other periphery connected?
I can connect UART for additional logs. Bootanimation was first time once and then restart.
@testbomber, please mount your sdcard in your laptop/PC and edit the cmdline.txt file. Change serial2 to serial0 to get the full kernel log during the boot via connected UART.
