Using vertical screens
My POS is using a touchscrren with a 1366(RGB) x 768 (SXGA) @60Hz resolution, on a vertical orientation.
Is ther anyway to set the resolution already inverted to vertical, or do I need to use the flip 90º config?
I ask, because just flipping the UX, when I open the camera in my application, it´s coming still on the horizontal.
Hi @JoaoFST
The screen rotation only applies to the OS. An application will decide for itself how it is rotated / displayed. The app may adhere to the OS settings, but it doesn't have to. So, I guess that's the Android stock camera app? If you do your own app, you can set the orientation as you please.
