Android 14 Bit Perfect Audio
Android 14 is supposed to come with bit perfect audio. But yesterday when I was using emteria on my Pi4B 8GB and I opened Apple Music and my DAC showed all output being sampled at 96Khz. I have a DAC HAT coming I don't know if I have the same problem there. But anyone else having the same issue? What is the fix?
Thanks so much!
hi @helloimajay
Did the DAC HAT fix it? I also think that the bit perfect audio isn't the default. Can you adjust that in Apple Music App? How are your headphones connected to the RPi?
