Uart Communication on Raspberry PI Compute Module 4 using Emteria OS based on Android 13
Hi,
I am trying to implement the example Serial app code provide in Emteria github on a Raspberry Pi Compute Module 4. I have updated the code to use sushell instead of su. But i am getting the following errors
type=1400 audit(0.0:2024): avc: denied { read } for name="ttyS0" dev="tmpfs" ino=406 scontext=u:r:untrusted_app_27:s0:c97,c256,c512,c768 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1 app=com.emteria.serial
type=1400 audit(0.0:2025): avc: denied { write } for name="ttyS0" dev="tmpfs" ino=406 scontext=u:r:untrusted_app_27:s0:c97,c256,c512,c768 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1 app=com.emteria.serial
type=1400 audit(0.0:2026): avc: denied { open } for path="/dev/ttyS0" dev="tmpfs" ino=406 scontext=u:r:untrusted_app_27:s0:c97,c256,c512,c768 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1 app=com.emteria.serial
type=1400 audit(0.0:2027): avc: denied { ioctl } for path="/dev/ttyS0" dev="tmpfs" ino=406 ioctlcmd=0x5401 scontext=u:r:untrusted_app_27:s0:c97,c256,c512,c768 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1 app=com.emteria.serial
Kindly let me know how to resolve for the same.
Regards
Sai Ram
  • Emteria OS version is 13.4.0
  • It works with Emteria OS version 11.11.0
  • Works with 14.2.0 also
  • Hi @SaiRam
    The errors are somewhat related but cannot be the cause, the part "permissive=1" tells you that in principle it would be denied, but it's still allowed - if that makes sense.
    Can you attach a full log? Any reason not to go with 14.2.0?
  • OK Thank you for the feedback, I am interested in 14.2.0 only, but the touch response was laggy as compared to 13.4.0 or 11.11.0
  • @SaiRam Understood. We are constantly releasing new versions, might give 14 a try every now and than. As for the issue with version 13, I would need a full log as the avc messages you have copied cannot be the cause for the behaviour you are seeing
