color problem
edited November 2024 in OS features
I live color problems with videos.For ex. faces are blue. How canI fix this problem. I installed stable release with rasperrry pi officiqal imager and update it to the latest stable release. I aso have sound problem. I couldn't get sound. I couldn't work the emteria with installing its own installer software.
Edit: After updating to the latest nightly build color and sound problem solved but sound isn't controllable from the emteria. you must use tv remote for it.
  • @Lazo Yes, I think colour issues are solved in v14.5.0
    There are RPi Settings in the drawer where you can select the audio output
