Problems with 3.5 inch touchscreen.
Hi! I currently got emteria installed on Raspberry Pi 4 but the 3.5 inch touchscreen is not working (ELEGOO Display 3.5" Zoll TFT LCD Touch Screen Monitor).
It worked fine with Raspberry OS. I think the Raspberry OS drivers will not work on emteria.
Can someone please help me? ![]()
New Link: https://amzn.eu/d/1t51ihH
@Kartoffelsueppchen It's not one of the already supported: https://emteria.com/kb/supported-device-peripherals-for-raspberry-pi-4b#screens
You could try to switch to fkms and see if it works. Otherwise you need to check what is loaded for RPOS and recreate it in emteria.os
@smieschek Many thanks for your answer! I will try that!
