Raspberry computed module 3 4GB is not enough
Dear all,
I wanted to try EmteriaOS. I bought one of the suggested board and specifically Artista IOT with 4GB CM3. But the installation cannot work: space is not enough.
So I can't try... Do I need to buy another 8GB CM3?
@Donatello Hi, I could reproduce this and I'm looking into a solution. As it worked in the past I don't think you need to buy another one.
@Donatello There is a new version of the installer online: v1.1-32. You should be able to flash Artista IoT with 4GB CM3 with it.
Yes, it's working!
Thank you.
