"No Signal" on Sony Bravia TV issue and how to fix it.
No matter what I did when I purchased Emteria, I could not get it to display on any of my TVs. And it literally took me months of trial and error, but I finally figured it out. This is for anyone else who is getting the same issue and can't get it to display on their tv screen, when it just says "no signal".
  1. Insert your micro SD card into the computer's sd card reader.
  2. Go to my computer, then to the drive where Emteria is installed and right-click on the config.txt and edit it with Wordpad.
  3. Change the line "dtoverlay=vc4-kms-v3d,cma-256" to "dtoverlay=vc4-fkms-v3d,cma-256"
  4. Then save, and exit.
5 (Optional). If this doesn't work, also try also adding these lines in the config
hdmi_group=1
hdmi_mode=16
hdmi_cvt=1920 1080 60 6 0 0 0
This will make it display in 1080p. And it should now load up and display on your TV screen.
